The problem starts when i downgrade the software.And i have picture on my tv screen but its only the wd log so icant come to the menu anymore , and the hub is not new.
Sounds like you shelled out money for a bricked WDTV Live Hub… Ebay ? How much did you pay ?
Previous owner probably bricked it while upgrading Firmware and hocked it online for a cheap price.
That did cross my mind Joey. But then I thought how could he even attempt to downgrade the firmware if it arrived in this condition.
I think it’s more a case of bricking it whilst playing with the firmware.
Yes sure, you can ‘attempt’ to downgrade the Firmware…but you should at least ‘see’ the WD Firmware Confirmation Screen to Update Firmware.
but if the unit is ‘bricked’ then it’s terminal.
Previous owner either turned off the mains power in middle of a Firmware Update … or tried to load WDLXTV Firmware.
If it was purchased on Ebay, i’d even check for ‘case tampering’ and investigate to see if the 1TB HDD is still in the case as well. (you know, bricked unit… salvage the hdd and hock it for 60 bucks)
