Drive will not mount, help!
My contents status comes up as “Not Mounted”, and I have zero space on the drive, and can not access anything.
Has anyone seen this before ??
Can I connect it directly to a PC or put the drive in a USB case to delete data ??
Regards
Did you try a factory restore from the admin UI?
Yes did that, system only.
was the drive full before the not-mounted issue?
I can not be sure, but that is what I believe happened.
I have a security camera that sends videos to the drive at intervals, and I think it filled the drive.
When I tried to log-on to delete - no can do !!
are you comforable going in with SSH? If not you probably need to contact WD support.
if so start by running df -k , then post the results
I downloaded putty, entered the IP address of the WDMycloud as the connection.
Putty just tells me connection refused ?
Hi just wondering what I should try next in ssh ? I posted the results, not sure if my share files are still on the drive.
parted -l
or
fdisk -l
ls /dev | grep sd
mount -t ext4 /dev/sda4 /DataVolume
mount -t auto /dev/sda4 /DataVolume
Run this. Post here. Wait answer.
Just want to check first, will the fdisk not format data I have on the disk and want to restore ?
Please see below -
WDMyCloud:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
rootfs          1.9G  747M  1.1G  41% /
/dev/root       1.9G  747M  1.1G  41% /
tmpfs            23M  3.5M   20M  16% /run
tmpfs            40M   64K   40M   1% /run/lock
tmpfs            10M     0   10M   0% /dev
tmpfs           5.0M     0  5.0M   0% /run/shm
tmpfs           100M  2.4M   98M   3% /tmp
/dev/root       1.9G  747M  1.1G  41% /var/log.hdd
ramlog-tmpfs     20M  7.0M   13M  35% /var/log
/dev/root       1.9G  747M  1.1G  41% /CacheVolume
WDMyCloud:~#
Display all 1212 possibilities? (y or n)
WDMyCloud:~# fdisk -l
WARNING: GPT (GUID Partition Table) detected on ‘/dev/sda’! The util fdisk doesn’t support GPT. Use GNU Parted.
Disk /dev/sda: 3000.6 GB, 3000592982016 bytes
255 heads, 63 sectors/track, 364801 cylinders, total 5860533168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x00000000
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1               1  4294967295  2147483647+  ee  GPT
Partition 1 does not start on physical sector boundary.
Disk /dev/md0: 2047 MB, 2047803392 bytes
2 heads, 4 sectors/track, 499952 cylinders, total 3999616 sectors
Disk /dev/md0 doesn’t contain a valid partition table
WDMyCloud:~# parted -l
Model: ATA WDC WD30EFRX-68E (scsi)
Disk /dev/sda: 3001GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Number  Start   End     Size    File system     Name     Flags
 3      15.7MB  528MB   513MB   linux-swap(v1)  primary
 1      528MB   2576MB  2048MB  ext3            primary  raid
 2      2576MB  4624MB  2048MB  ext3            primary  raid
 5      4624MB  4724MB  99.6MB                  primary
 6      4724MB  4824MB  101MB                   primary
 7      4824MB  4826MB  1049kB                  primary
 8      4826MB  4828MB  2097kB                  primary
 4      4828MB  3001GB  2996GB  ext4            primary
Model: Linux Software RAID Array (md)
Disk /dev/md0: 2048MB
Partition Table: loop
Number  Start  End     Size    File system  Flags
 1      0.00B  2048MB  2048MB  ext3
WDMyCloud:~# ls /dev | grep sd
sda
sda1
sda2
sda3
sda4
sda5
sda6
sda7
sda8
WDMyCloud:~# mount -t ext4 /dev/sda4 /datavolume
mount: mount point /datavolume does not exist
WDMyCloud:~# mount -t auto /dev/sda4 /datavolume
WDMyCloud:~# ^C
WDMyCloud:~#
  D ata V olume
This is what the unit returns -
WDMyCloud:~# mount -t ext4 /dev/sda /DataVolume
mount: /dev/sda already mounted or /DataVolume busy
WDMyCloud:~# mount -t auto /dev/sda /DataVolume
WDMyCloud:~#
Interesting…
Try this:
ls /DataVolumeumount /DataVolumeumount /dev/sda4
mount -a
or just mount to another folder:
mkdir /mnt/hdd
mount -t ext4 /dev/sda4 /mnt/hdd
Angry !!
WDMyCloud:~# ls /DataVolume
backup  cache
WDMyCloud:~# unmount /DataVolume
-bash: unmount: command not found
WDMyCloud:~# unmount /dev/sda4
WDMyCloud:~# mount -a
WDMyCloud:~# mkdir /mnt/hdd
WDMyCloud:~# mount -t ext4 /dev/sda4 /mnt/hdd
mount: wrong fs type, bad option, bad superblock on /dev/sda4,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail  or so
WDMyCloud:~#
Possibly sda4 is broken.
Use Undelete+ or another rescue software for restore your data.
Then - Go to web interface and chose “Factory restore” (With deleting user content. Full)
