Dvr-ms playback problems
hi all I finally set up my wdtv live Which directly connects to my windows 7 htpc via cross over…I have no problems seeing both from either end and have set up all my network shares… It works flawlessly playingback avi files And DVDs that have been converted to mkv…the only prolem I have is when it comes to playing dvr-ms files that have been recorded from my dual tuner the files are wtv but have been converted to dvr-ms but when I play back the files there is a stutter in the video every 20 seconds or so?? Any suggestions? Thanks
no one having this problem playing drv-ms?
thanks
It’s probably not a format many are trying.
i wouldhave thought a few would be using it as that or wtv are the recording formats from windows
I have exactly the same problem but I recently upgraded to the latest beta firmware, then noticed I could access my NAS via Media Server or Network share.  When attaching via Media server I get the stutter, when choosing Network share no stutter.  dvr-ms have been recorded as wtv, then converted and moved to the NAS (Qnap210).
Sorry, my mistake, there is no change…the stutter is present whichever way I access the file.
