EX2 Ultra both hard drive lights are off, can't see in network anymore
I have a cloud ex2 ultra and so far it’s worked great for me until yesterday when I noticed I couldn’t find the nas drive under network in my computer. I restarted the computer, reset my router and modem, then rebooted my nas drive, the power light comes on solid blue but neither of the two drive lights come on and I can’t find the drive via the network.
I do recall the 2 hard drive lights used to be on solid like the power light but I am not sure what exactly has happened here I ran the system test within the cloud dashboard came back as a pass, I just don’t know why I can’t see the drive anymore in network and both hard drive lights appear to be off.
Strangely I can still access it via plex in my browser and via the cloud on iphone to see play music or video, so I don’t think the drives went bad or anything I just have no lights and can’t see the nas drive itself via network anymore.
The fact that Plex and the iphone can see it indicates it’s likely not a problem with the drive but with the computer. A lot of things can cause a PC to be unable to find network resources.
What have you changed recently on the PC? Do you have anti-virus software installed? Do you use Windows firewall? Are you able to access your routers homepage?
I figured it out I think but still have one problem, I think I hit hibrernate in the dashboard and that’s when the lights went off, I read I had to unplug the cat 6 cable and unpower the unit, once I did that the 2 drive lights came back on as hibernate is now the shutdown via the most recent firmware update.
The problem i have now is I still can’t see the nas via my network under my computer (previously I was able to see it and access it fine).
I have reset my modem, router, pc, even changed which port my cat6 cable goes into on the router, rebooted the nas as well, I can access it thru the cloud software via iphone and the plex nas server is running i can view videos from directories i setup on it, just can’t see the nas via computer/network area where i normally used to see it.
I am running avast antifvirus no real changes or anything software wise or firewall wise, I can access my routers homepage, I can see the nas drive with it’s ip address and shows its connected via ethernet cord, I can access the dashboard via that ip address too, just can’t see it under computer/network like i can see all the other computers in the house.
Try (very temporarily - undo this as soon as you test) to disable the anti-virus and firewall. Once this is done, try mapping a drive letter to the drive (instructions below) and see if it can establish a connection:
Yep disconnected firewall and turned off antivirus yet when i go to map the drive it’s just not showing up under browse/network to be able to assign it ;(
From what I read here in forums and thru google is sometimes the drive after rebooting takes a bit to just recheck it’s files and whatnot, maybe I will just check back tomorrow do a pc/router/modem reset leave the nas alone and see what results that gives me, it could just show up again like before.
Ok unmap the drive.
Do this if you have reserved the address for the NAS type in the explorer and you should see the shared folders
At times the broadcasting is not working. But it will be able to resolve it self
Hope this works. You can check the nas IP from your Router attached devices.
I would unmap the drive but it isn’t even showing so I have nothing to right click to unmap.
