EX4 constantly looses/forgets ISCSI target
One of my EX4 looses/forgets its ISCSI targets after reboot. I tried all resets incl. 40 sek. reset and now also changed the internal battery, but with no result. If i import a saved configuration, the ISCSI targets will be back, but are not accessible. Windows ISCSI-Initiater mounts them, but the drives do not appear in the disk/partition manager. After the next reboot they are also again disapeared.
The internal error message is: The data volume X on the drive is not accessible. Contact WD Support.
The disks are fine, i also tested different.
Has some one a solution?
Hi @HENRIK_SCHNETGOKE
Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting:
