Extended Test Read Failure
I’d been testing this new drive and everything was well until it suddenly failed an extended test.
smartctl 6.0 2012-10-10 r3643 [i686-linux-3.7.5-pmagic] (local build)
Copyright (C) 2002-12, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital RE4 Serial ATA
Device Model: WDC WD1003FBYX-01Y7B0
Serial Number: WD-[Deleted]
LU WWN Device Id: 5 0014ee 2b13c0ab7
Firmware Version: 01.01V01
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Wed Jun 19 13:14:52 2013 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82)	Offline data collection activity
					was completed without error.
					Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: (15960) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities: (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability: (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 165) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303f)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 2
  3 Spin_Up_Time 0x0027 195 194 021 Pre-fail Always - 3250
  4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 11
  5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
  7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
  9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 114
 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 11
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 9
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1
194 Temperature_Celsius 0x0022 110 105 000 Old_age Always - 37
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 114 -
# 2 Extended offline Completed without error 00% 106 -
# 3 Extended offline Completed without error 00% 98 -
# 4 Conveyance offline Completed without error 00% 90 -
# 5 Extended offline Completed without error 00% 84 -
# 6 Short offline Completed without error 00% 81 -
# 7 Extended offline Completed without error 00% 78 -
# 8 Selective offline Completed without error 00% 71 -
# 9 Short offline Completed without error 00% 66 -
#10 Extended offline Completed without error 00% 65 -
#11 Conveyance offline Completed without error 00% 53 -
#12 Extended offline Completed without error 00% 45 -
#13 Extended offline Completed without error 00% 36 -
#14 Short offline Completed without error 00% 28 -
#15 Extended offline Completed: read failure 30% 26 1431138240
#16 Extended offline Completed without error 00% 17 -
#17 Short offline Completed without error 00% 14 -
#18 Conveyance offline Completed without error 00% 0 -
#19 Short offline Completed without error 00% 0 -
1 of 1 failed self-tests are outdated by newer successful extended offline self-test # 2
SMART Selective self-test log data structure revision number 1
 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
    1 0 0 Not_testing
    2 0 0 Not_testing
    3 0 0 Not_testing
    4 0 0 Not_testing
    5 0 0 Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Since then it has passed all tests but I’m wondering if anyone would like to comment on whether this should be a cause of concern (I’ve bought 2 other of these models and neither has ever had a test fail despite having been tested as many times).
I believe I probably used DD to write zeros to the entire drive after that test (I had previously formatted it once before the test).
(Another thing is the Multi_Zone_Error_Rate, whose raw value increased to 5 or so during testing before dropping to 1 some formats and tests later, I don’t think this is an issue but anyone who has some knowledge or experience in these matters can chime in on it.)
The read test failure is what has me really worried despite not cropping up since, there was a study I believe that said once you get a test failure the chance of the drive going bad within some months increases by a third or something.
Thank you.
its true. most drives fail either in the first three or many years later.
I do not think that the initial read error is cause for concern, but im no expert. Keep an eye on that drive for the next few months to come and if nothing changes by then, I believe you are safe for years to come.
My RE3 and RE1 drives have over 2 years and 3.5 years power on time with no reallocated sectors and only 2 read errors across all six drives. Quality :slight_smile:
I’ll be sure to monitor it, thanks.
But I am curious, would another test with read failure be enough to justify (at least from WD’s perspective) an RMA to warranty it? If not, how many tests would it have to fail?
With S.M.A.R.T. attributes at least it is fairly clear when something is very wrong (and continues to be).
