Fed up with WD 20EARX Green drive
hello guys
By mistake i bought wd20EARX 2TB From 10-12 days ago ,the very next day i have to rma it due to bad sector n freezing ,now yesterday i got new 2tb 20EARX Drive ,after installing ,wehn i run the hd tune i got lots of damaga block :frowning:
Data Lifeguard Diagnostic for Windows is also not able to fix it ,its showing error :frowning:
now what should i do ? should i rma it again or is there any method tho fix it ?
all the 2 TB green are fail drive or what ? :angry:
Contact WD and request another model number, I have seen it before they will provide you with another model number if you are having issues with your drive.
i have already send  the drive ,i will contact them regarding it !! hope they will do something about it
thanks buddy for suggestion :slight_smile:
