I have a MyCloud Mirror Gen 2 loaded up with movies and TV show which I often stream to a Roku, iPad, or Chromecast. By and large, this device with their plugin works great. But I experience an issue that I haven’t seemed to find support for on Plex’s forums or Reddit.
I can be at home, work, or a friend’s and try to log onto Plex only to find that the libraries on my MyCloud are not available. I can log into the drive from the wdmycloudmirror/ dashboard or I can see the drive on Windows Explorer, but Plex has some kind of disconnect.
Recently, someone suggested that I turn off the Drive Sleep feature in order to keep it connected. I did this, but I still experience the same issue.
The only thing that I can consider to be a potential culprit has to do with my router. I have Optimum Online in NJ, and we have the router provided by the ISP. It has proprietary firmware, although I have managed to set up the Port Forwarding properly. I saw a user on Reddit complain that the DNS settings from Optimum gave them trouble, but I’m not savvy enough to understand what effect that had and if it applies to my situation.
https://www.reddit.com/r/PleX/comments/4e7deg/cannot_reach_plex_on_lan_only_on_wan_yes_the/
Any help or direction anyone can provide would be immensely appreciated. Is this a WD issue or Plex?
