This program is a nice alternative to SABnzb but not quite as powerful
This program does give you a nice speed boost over SABnzb
It maxed out my 30Mb connection without breaking a sweat
Connect to the MBL with PuTTY or Terminal and install optware
wget http://mybookworld.wikidot.com/local--files/optware/setup-mybooklive.sh
sh setup-mybooklive.sh
Issue the following commands to ensure that we can use the command “ipkg” from any directory
echo "export PATH=$PATH:/opt/bin:/opt/sbin" >> /root/.bashrc
echo "export PATH=$PATH:/opt/bin:/opt/sbin" >> /etc/profile
Close PuTTY or Terminal (Very Important)
Open PuTTY or Terminal and connect to the MBL again
ipkg update
ipkg install nzbget
Copy example configuration file to /etc or /opt/etc
cp /opt/share/nzbget/nzbget.conf /opt/etc/nzbget.conf
Start NZBGet
nzbget -s -o outputmode=curses
Login to NZBGet using your browser at MBL Network Name or IP:6789
For authorization to the web-interface use predefined username " nzbget" (not configurable)
Password: tegbzn6789
Setup your download folders
Go to Settings/Paths and change it to /DataVolume/shares/ whatever share you would like
Click save all Changes
Click Reload NZBGet
Set the path to unrar
Go to Settings/unpack/UnrarCmd and change it to /opt/bin/unrar
Setup your news servers
Go to Settings/News-Servers and setup your News-Servers
Click Reload NZBGet
Change the WEB UI password
Go to Settings/Remote Control/Control Password to change the Web UI password
Click Reload NZBGet
Browse around settings and make any other changes you might want to
Close out the web browser and go back to your PuTTY or Terminal Window
Click in the window and hit Q to quit NZBGet from running
Add NZBGet to auto start on a MBL reboot
nano /etc/init.d/nzbget
Paste this into the window (right click your mouse button)
#!/bin/sh
# Start/stop the NZBget daemon.
case "$1" in
start) echo -n "Start services: NZBget"
/opt/bin/nzbget -D
stop) echo -n "Stop services: NZBget"
/opt/bin/nzbget -Q
restart)
$0 stop
$0 start
*) echo "Usage: $0 start|stop|restart"
exit 1
esac
exit 0
Hit control and o
Hit enter
Hit control and x
This will save your edited file
Set the script permissions and add it to all the rc folders
chmod 755 /etc/init.d/nzbget
update-rc.d nzbget defaults
Start NZBGet again
/etc/init.d/nzbget start
DONE!
