Hi there, after an power shutdown the main page of the local dashboard shows zero data capacity. None of the harddisks are shown in the raid profile.
I got the following notification message:
“File System Check Failed
File system check has detected errors on your drive configuration. Backup your data and recreate the drive configuration to resolve these errors. Code: 36”
Disk status tells me thet the HDs are in good condition. Problem is, when I try to reconfigure the HD
s, OS 5 gives me no opportunity to do this without formatting the drives, which means, Im going to loose all my stored data. The fact, that the drives are encrypted, doesn
t makes it easyer. Otherwise I would connect the drives to my PC to backup them.
Any solutions?
My Cloud EX4 hard-drives My Cloud OS 5 Personal & Network Attached Storage
