Help with Mycloud
Hi - i’m looking for help in setting up mycloud at home to play movies and music through a DLNA device (xbox).
I’ve managed to get all my movies to the cloud and stream through xbox.
However i’m confused as to how i should setup my music.
Currently my music is on an external hard drive and this has caused my problems with itunes and synching.
However, from what i understand, the Mycloud has ability to network music library with itunes.
Do i need to install WD link (i use Win7)? Will itunes find mycloud as a shared resource without Mybook live or somesuch?
I know this has probably been answered somewhere, but if someone could explain in simple terms how best to setup i’d appreciate it.
Thanks,
Andrew
Hello, to stream music to iTunes, verify if the iTunes server is enabled. Check page 82 of the manual for more information.
http://www.wdc.com/wdproducts/library/UM/ENG/4779-705103.pdf#page=87
