Hi ,
Yesterday i changed my internal hard drive name to “MovieCollection1” the name before was “asdfgh” ( without quotas of course "… ok so now all my movie info and covers are gone…i went into my metadata folder ->movie->movie.xml and edited the location like this :
file:///tmp/media/usb/Local/WDTVLiveHub/asdfgh/2012 (2009).avi
to
file:///tmp/media/usb/Local/WDTVLiveHub/MovieCollection1/2012 (2009).avi
and i restarted the WDTV LIVE HUB and turned off and then back on media library … and its not working…
and the funny part is that since i didnt see the movie cover and info … i generated a movie to check were the metadata was pointing…
so i opened up the movie.xml and had the same name as the one i changed …
file:///tmp/media/usb/Local/WDTVLiveHub/ MovieCollection1 /2012 (2009).avi <— the one that i renamed
and the new one that was generated was :
can u someone please help … i dont want to generate all my movie titles again :S
