How disable the "click sound" in WD scorpio blue?
WD5000BPVT in few seconds is done an internal “click” sound and does that same action several times.
I not understand if is an hardware failure.
The HDD works correctly and not is reported any problem.
That “click” sound is related with any power saver feature ? How disable that “click” sound for both computer and gaming console ? Is possible using the jumper connector ?
Thanks for reply.
Hi @aug,
Please refer to the article Western Digital Hard Drive Noise:
If further assistance is needed, please open a case with our support team at the following:
