How to autosync between MyCloudMirror and specific folders on PC?
I purchased MyCloudMirror and been using a couple of months. But I have never figured out how to use the feature that made me bought it, the auto sync. Am I misunderstood the feature and capability of this device?
My purpose is using MyCloudMirror to auto sync some of my folders on my PC. Whenever I make any changes on the destination folder on PC, or the same folder in MyCloudMirror device. They will always in sync with each other. MyCloudMirror do have such feature right?
I saw WDSync folder in MyCloudMirror that is built-in by default, and I also see the “TimeMachineBackup” in the MyCloudMirror admin management console. But I couldn’t find any instruction in the official manual telling me how to do the auto-sync stuffs.
I need help please. How to set up the auto-sync / auto-backup things? When can I find the proper document / instruction that tell me the walkthrough? Thanks for help.
Hello, mynmonic
http://support.wdc.com/support/case.aspx?lang=en
