Hi, I’ve just bought a new WDTV Live and i’m having some troubles with it, and i think both of them are caused by the same thing.
I’ve connected a external drive on wdtv where all my media files are, along with other files such as Backup files. So, the first problem is that those backup files are shown in the media library. Is there a way to configure it to ignore some folder? Maybe adding a prefix into folder’s name?
The other problem is that info scraper never stops. I’ve already let it work for many straight hours and it keeps working. I’ve tried to clean all metathumb/xml files and “.wd” folder before it begin but the result was the same. I think it is because it is trying to get info to all files in backup folder. So here is my question, is it normal to take that long (eg. more than 6 hours) or it is really a problem with the number of files?
Thanks!!! And beside that everything is working like a charm!!!
