Hub is restarting randomly
Since few days, my hub is restarting itself when i am navigating in the menu. It is a hard restart, with new library update.
It is not happening when watching a movie.
I tried to unplug the device and to disconnect from internet, but still rebooting alone.
Any help welcome to troubleshoot this issue.
I believe you’re seeing a firmware bug in 3.03.xx.   Same bug in the SMP version 1.07.xx.
If you are, the only remedy is to roll back the firmware.
For what it’s worth
I would try flashing it again. If you did an over the internet update to get to 3.03, then I would definately flash it again. This time do it from a USB stick.
If you DO try it again:
BEFORE you flash it do a factory reset, I would use the reset button on the bottom of the Hub.
AFTER you flash it do another factory reset the same way.
If that didn’t fix it THEN I would roll back. You have nothing to loose but a little time and a lot to gain if it works.
I have the same problem and, like Tony, I believe it is a firmware bug.
