Hi everybody,
I’m having serious issues with my EX4, both performance and reliability.
To start with, I have the EX4 configured with raid 5, running 4 4TB drives. It’s connected to any given machine over dual 1Gb/s cat 6 ethernet cables, firmware version 2.11.140. Everything that can be disabled is disabled, it’s sitting there as a dumb raid device with no cloud access and no media servers, ftp server, itunes server, etc… The only thing that’s not disabled is the web interface.
Problem 1: The file transfers for large and small files is horribly slow, talking 1.5MB/s to 4MB/s (write/read) for text, video, picture files. That speed will bump up to 2 / 6 for large single archive files. I’ve disabled just about everything that can be disabled to try and increase the speed, it’s helped but as you can see, not by much.
Problem 2: Encrypted sparsebundle DMGs…trying to transfer files is near impossible. I have (had) an encrypted DMG on the EX4, mounted to a machine over the above stated connection and was getting transfer speeds of 10-15 KB/s…as if we were back in the early 1990s. What gives? They claim this is a TimeMachine backup device, well how could that be possible when time machine uses encrypted sparsebundle DMGs and you can only write at 10KB/s?
Problem 3: Mounting USB drives to the back, once mounted the button to turn off “media serving” is greyed out and stuck in the “on” position, which is counter to what I want. Performing a “copy” backup from a EX4 directory to a directory on the mounted USB drive is impossible since it claims the drive directory is read-only (verified that it’s not). However if I turn on “public access” for the mounted drive it suddenly works, thanks for the security problem…
Problem 4: Security policies (haha), newly connected drives are mounted as public by default, newly created stores are public by default, and give permission to all users to R/W. Connect a drive and anybody can see it, great plan.
Problem 5: Changing settings on the web interface sits with the “Updating” message for hours on end and never updates a single setting.
Obviously I’m a bit baffled how this thing is selling. I don’t understand how people are putting up with these kind of write / read speeds (given all the posts these issues don’t seem to be limited to me). Writing to an old (6+ years) USB HDD that’s connected to a switch through a hacked together ethernet → USB adapter gets 100MB/s throughput for read and write, ■■■■ close to the absolute max for both the HDD and the cat 6 connection.
Before I yank out the HDDs and melt this thing down is there anyway to fix it and get reasonable R/W speeds and reliable USB drive connections (a responsive web interface would be nice too)?
