I have some .MKVs that for the first two minutes of the stream, the audio is a 2Ch signal. After that, it is AC3 5.1. For some reason however, the WDTV only plays it as stereo throughout. Is there something I am doing wrong, or something I can adjust with the file to make it play the 5.1?
Thanks.
Please post the full TEXT output of MEDIAINFO for such a file.
http://mediainfo.sourceforge.net
General
Unique ID : 230369465152351350116235453513638344092 (0xAD4F8B8D0BBB5A4ABA3343E91897F59C)
Complete name : test.mkv
Format : Matroska
File size : 2.36 GiB
Duration : 57mn 26s
Overall bit rate : 5 884 Kbps
Movie name : test.mkv 15297
Encoded date : UTC 2011-04-26 07:51:19
Writing application : mkvmerge v4.6.0 (‘Still Crazy After All These Years’) built on Mar 10 2011 02:50:32
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 9 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 57mn 26s
Bit rate : 5 500 Kbps
Width : 1 280 pixels
Height : 714 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.251
Stream size : 2.16 GiB (91%)
Writing library : x264 core 115 r1936 7a9e08d
Encoding settings : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=tesa / subme=10 / psy=1 / psy_rd=1.10:0.10 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=8 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=12 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=5500 / ratetol=1.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:0.60
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 57mn 26s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 158 MiB (7%)
I notice that it states that it is 2.0, but I am wondering if that is because it starts out as such.
If it says 2.0 then that is what it is.
Never heard of an audio stream that can change the number of channels.
Yeah, it can be done… Like recorded TV, commercials are usually 2.0 but the main program is 5.1. I’m not sure how MediaInfo reports on that, or if MKV can do it.
What about another format? Maybe I can demux it and do something else with it?
