My Mirror won't wake up!
This happened after my unit was shut off for a week. When I powered on my system I have 2 choices:
Wake this device
or
Forget this device
I’ve hit Wake a number of times, tried rebooting, tried the 4 second reset, then the 40 second reset…
Still same condition. What should I do next, uninstall and reinstall everything?
Thanks for any help,
Ben
Hello, Igneous
You should try contacting WD’s Technical Support about this for live assistance and troubleshooting
The link below will allow you to call support
