I bought two of these as refurbs straight from WD. And both are DEAD upon receipt. The replacement ones came and one out of the two is also a dud. The symptoms are exactly the same. They show the splash screen, and then nothing, not even after 10-15 minutes. RCA doesn’t work either. The CSR said they are defective.
So the refurb units have a high rate of failure/DOA in my experience. They are probably never tested and just reset and resent. Luck of the draw i think.
