arrggh! my live has been working great until last week now i cant do anything with network shares (it just sits there not responding to any button) the media shares still work from both pc’s but nothing from the network shares
only thing that changed last week was the addition of a new tv a samsung, i installed the allshare software but promptly deleted too as it didnt serve any purpose to me as i have a wdtv live! i have tried every fix available on the net but cant get any to work has anyone got any ideas please
all my internal networking is working fine i.e. pc to pc and my wdtv can also acces the online features accuweather etc
ok , then pls check on your pc/laptop network area [firewalls,options,is there the name WORKGROUP ?]
try to “map” all hdrives
and ?
regards
pawson
edit : you are having a router/modem ? if that is so - then pls change cables and plug in into other rt-45 ports and turn on and back return the cables into normal/previous position and check - maybe that is something with your Dns…[static ip or nat ?]
changing for a while cables/places [rj45 within my router] works in my case [once a two months I have to do that once my network restarts and then do not “see” all devices,after that operation it does ]
