i got a new 1TB WD HDD and I’ve done everything to make it show in my disk management but it shows in my BIOS, I’ve updated all my drivers. also ran test to see if the HDD was dammaged and it was not. i’ve tried all my SATA ports and it wont work on any of them. i also have a 120gb SSD with my windows op system on it and my HDD has nothing on it.
Hi Skyblack62899,
The link below will allow you to call support.
