Permissions problem
hi
i can’t access my share after setting permissions.
i turn off the public access and set user permissions, now i can’t access the share
any suggestions?
Ok, what happens?
i get network error:
windows cannot access \wdmycloud
you do not have permissions to access …
i try to remap network drive with other credentials but still cannot access the share
if i set the share as public i can access any share i want
Open up a CMD window as administrator.
Execute the command
net use * /delete
now try to access your private share.
thx for fast answer but still no access
again the same network error
There for sure is some problem with permissions.
As long as FTP service is disabled SMB share is working OK, but as soon as FTP service is enabled I have the same problem as described.
I don’t have permission to access folders that are set for public or to specific user.
Funny thing is that some are accesable and some are not.
After FTP service is disabled again all folders are accessible.
Why is that so?
