Please Help my Component output seems to be abnormal and greenish. Anybody faced this issue
Hi all
I bought the WDTV Live barely 3 days ago. When connected though HDMI or Composite cable ( Red / White / Yellow) the pictures are normal. But when I connect through Component ( Red / Green/ Blue )the picture is greenish.So whatever i watch has a greenish hue or in other words unwatchable.First of all wheher this is normal. If not then what shall i do guys. I tried lot of settings tweeking but no avail.  Anybody facing the same problem and ultimately able to solve it  please tell .Am I eligible for a replacement. Also I am from Kolkata , India. Can anybody tell me the Service center address of Kolkata. I am sticking on the screen images of both the inputs.
Component : http://img713.imageshack.us/img713/5081/componentconnection1.jpg
Composite : http://img220.imageshack.us/img220/8417/compositeconnection1.jpg
Please help people.
Regards .
S.Biswas
No, that’s not normal.
Make sure the 3.5mm plug is COMPLETELY inserted into the WDTV.
Make sure the color RCA jacks match colors correctly.
Make sure the COLOR-SPACE setting (RGB / YUV) matches what your TV expects.  Most TV’s want YUV.
If that doesn’t address the issue, then try this:
Remove ONE RCA PLUG at a time from your TV.   Does the picture change with all three?   Or is there one plug that does NOT change the image when it’s removed?  If so, which plug is it?
Hi
Ya . I figured that out. Now the problem can be in 3 areas .
  1. The WD TV Live player
  2. The cables
  3. The sony TV.
How to detect that.
And again I cannot test it in the old CRT . TV It had component jacks but do not sup[port progressive.
And Wd tv starts with 480p.
Can anybody suggest anything?
Well, if your TV only supports 480i, then you must use composite.   You have no choice.
Actually, you could use a Video Scaler… but that will cost much money.
Hi  all
Thanks for your support
The issue has been resolved . There was a problem with my display unit.
WV TV Live seems to be fine
Regards
Biswas
