When I transfer files the transfer often gets interrupted and I have to try multiple times just to get single movie files to go. I get the message “The operation can’t be completed because the item “whateverthefilenameis” is in use.”
My setup:
-WD Hub hooked up to my router
-WD MyBook (2TB)
-MacBook Pro running Mavericks
So I’ve transferred videos thousands of times via Finder from my Mac through the connected Hub to the external hard drive (MyBook). A little while ago (roughly the time I updated to Mavericks) these problems started and they’re really annoying. They could become a major problem for me next time I need to do a mass of files all at once.
I am assuming this is related to the well documented incompatibility between OS X Mavericks and WD Hard Drives.
There was a fix released yesterday for external drives - hopefully a firmware update is released to addressed this. I am having the same problem since Mavericks was installed and it is driving me crazy. WD had MONTHS to prepare for this and they dropped the ball.
