Question about 7.1 passthrough
As a WDTV Live user I was trolling the Hub forums when I noticed the 7.1 passthrough update in FW 2.04.13
Can someone please explain exactly what this enables?
Is it DTS-MA / Dolby TruHD passthrough?
PCM passthrough?
Thanks,
BR
Where did you see that?    As far as I know, there’s no such capability…
Look under the Version 2.04.13 details:
http://support.wdc.com/download/notes/WDTV_LiveHub_ReleaseNotes%202_07_17.pdf
Supports 7.1 channel audio passthrough.
Updated audio passthrough options menu.
I was just curious what this was…
Thanks,
BR
Ahh.   I’m guessing that’s 7.1 channel PCM.
Dobly TruHD *is* supported in certain containers (namely TS and M2TS) , but I’ve never come across a 7.1 channel source.  All of my BD’s are either DTS-HD MA or Dolby TrueHD 5.1.
DTS-HD MA 7.1 is definately *NOT* supported.
Thanks TonyPH12345
BR
