The firmware pre-release 1.03.22 added wireless adaptor support for ASUS USB-N13
My question is, do the newer pre-releases have support for this adapter too?
I bought it after seeing the list of supported adapters but before knowing that it was only supported after changing the firmware. Now i dont know what to do.
It does say on the release notes that support for the Asus USB-N13 was added with firmware 1.03.22 but it also says on the approved list:
The following devices have been tested and are known to be compatible with the WD TV Live HD Media Player (using firmware 1.02.21) and the WD TV Live Plus HD Media Player (using firmware 1.03.29_b).
Works good. I occasionally get a problem with the connection slowing to a crawl though. I’m 100% sure its not the network, because rebooting the wdtv seems to rememdy the problem.
Not quite sure what causes it. It’s pretty common too.
