Remote Access / Mount
Yesterday I enabled a noip account so I could access my remote shares from another WAN.
If I ping to my WDMyCloud I get response, but I already tried to access via SSH, WebDAV, FTP and I can´t.
Is it possible to access a share remotely or mount it in windows/mac or do I really need to do it from WD2Go or install OwnCloud?
Thanks.
<If I ping to my WDMyCloud I get response, but I already tried to access via SSH, WebDAV, FTP and I can´t.>
You will need to forward the ports from your router to the NAS. Of course, first you have to setup SSH and FTP first on the NAS.
<Is it possible to access a share remotely or mount it in windows/mac or do I really need to do it from WD2Go or install OwnCloud?>
Yes, but only recommeded via SSH.
You could open the TCP ports needed for remote mount as in you were in you own house, but those are BIG security risks.
I recommend nothing but SSH (22) for remote access, it is pretty much the only secure protocol, HTTPS/443 the other. Even then, you can get hacked, make sure you have a strong password and disable root remote login.
Other option to do somehow VPN into your home.
