And if you open the wdtvlivehub.ver file in notepad you see VERSION=‘4.00.28’. If you see this in the file and it still will not work make sure the update option is on in the setup. If that does not work then you could try a flash drive formatted to fat32.
Thanks for help so far.
Yes VERSION=‘4.00.28’ is there.
Do you mean the option that says ‘update to latest firmware automatically’ or something along those lines?
