Hi
I have just added an external WD Elements 2TB USB drive to my live HUB, I backed up the films folder from the HUB to the USB drive whick worked ok. I also added some extra movies to my USB drive in the films folder, but when I press the red button for the source in Video, I get Local Storage → Internal Storage or USB2, I cannot select both, how do I select the option to view both? I’ve seen a few posts on here quoting ‘all local storage’ but that’s not an option on mine.
The USB drive is showing when I use the file options and I can select it as a source, so the HUB is definitely seeing it, I’ve restarted the hub and reconnected the USB drive, but still no luck.
I have also switched off the media library as it was constantly flashing for hours and would not let me into any folders, probably caloguing my 500GB backup folder ! is there any downside to doing this ?
Thanks for any advice.
