Setting multiple backups
Using WD Smartware, under Settings, set 5 backup versions of all files, only ever have one on the Passport
Have you looked under the Retrieve tab of SmartWare and checked it out? Mine is set to keep three copies. Look at our movie list. Because it changes often you will see three copies and their dates. Click on, tap or activate image to enlarge it and see complete image.
