Over the past couple of days, I’ve had a problem with the sound going away, then coming back (after pause/restart), then going away again, and so on. I use the WDTV exclusively for watching Netflix and streaming via PlayOn, and the sound issue has occurred with both. Thinking maybe an hdmi issue, I tried different cables, same problem. So I was going to switch to component, but when I go in an change the audio/video to component and disconnect the hdmi cable, I get nothing. No picture. No sound. Nothing. If I have hdmi AND component connected, I get both. Unplug hdmi. Nothing. I did a factory reset and started over. Same thing.
I’m just an old granny so please don’t get too technical, but if anyone could clue me in as to what I’m wrong here, I’d really appreciate it. Please and thank you.
