Transferring dvd and Blu-ray movies
For some  reason, I can not transfer any dvd or blu-ray that is 3gb and over to my exteral mybookklive Duo,  I get an error that says upload incomplete each and every time I try to transfer a movie.
I’ve never had a problem like this. It is probably a stutter from your router.
try it by having both devices connected via ethernet to the router.
Thank you very much guys.  It works now…Thanks again.
Bryon,
Mark the thread as solved and post the solution. It could help someone down the line.
