I have a WD My Cloud which I was using up until a few days ago. I was trying to run time machine backups on to it but it was not working so I thought maybe the firmware needed to be upgraded.
Accessing the Web UI with my admin password was problematic so I was forced to reset the device today and now the device is no longer showing disk space usage. It had some tasks for scanning media which were cancelled so now I can’t see what is on the hard drive.
I have done a hard reset and also a system reset but nothing is working properly anymore.
I also tried manually upgrading the firmware to OS 5 and its giving me a message that there is not enough disk space to complete the upgrade.
First, the first generation single bay My Cloud running v4.x firmware cannot be updated to OS5 v5.x firmware. The v4.x firmware cannot be updated to the 2.41.116 (12/08/2020) second gen single bay My Cloud firmware that is needed to update to OS5 v5.x firmware. Your screen capture, indicated by the Safepoint tab, indicates you have a first gen single bay My Cloud running the v4.x firmware.
Did you try a 40 second reset to see it that resolves your issue(s)? See the following WD Support Knowledge Base Article for how to perform a reset of a single bay My Cloud device.
I’ve just tried to do a 40 sec’ Reset, tried twice and nothing, will not reboot. Followed the instructions ( How to reset a My Cloud single bay device ), but zero. Could my ( one for a better word ) motherboard be corrupt ?
Oh one more Q, would you happen to know if the HD in My Book ( for Mac ) have the Firmware installed on it ?
What My Cloud model and what firmware is your My Cloud model running? This thread was discussing issues a person who had a first generation single bay (v4.x) My Cloud was having.
If one has a second generation single bay My Cloud (or any of the OS5 supported multi bay My Cloud models) that has been updated to OS5/v5.x firmware then one may be experiencing the “indexing” that cripples and renders some My Cloud models unusable while the indexing is being performed. The workaround suggested by WD in that case is to disable remote access/cloud access and the Twonky media server (if installed) through the My Cloud Dashboard.
For the single bay My Cloud models one can replace the hard drive within the unit with another hard drive. There is a specific process of partitioning, formatting and installing the OS3 firmware. The process and files used are different for each generation version of the single bay My Cloud. Search (via the forum search feature, magnifying glass icon upper right) the OS5 subforum for “unbrick”, there are numerous discussions involving a variety of methods.
