Hi guys. I have found this forum an amazing source of info. Some very knowledgeable people here. I certainly want to have some modified scripts to improve this device. nfodiz seems well on the way with these.
I have a mybooklive 2TB that we’ve had for only a couple of months. I too have done an web update.
I am having the Blank UI and ssh pages issue, didn’t start straight after an update I don’t think.
Twonky :9000 UI pages works fine
Transmission not working at all
I do not have SSH enabled. It used to work.
In http://community.wd.com/t5/My-Book-Live/Can-not-longer-access-mybooklive-UI/td-p/265430/page/12 Tim_B55 suggested refreshing the /UI and /ssh pages to get it to appear while in the initializing stage. This does work but not all the elements appear. By that I mean I can click the check box to enable SSH but there is no save or cancel buttons at the bottom. I noticed this just before the pages started to go missing. The Main /ui page only have the “How can we help you” sidebar appearing. “Secure your device” appears at the top but doesn’t do anything.
If the device gets to the green LED stage, the pages are empty but the WD logo appears in the browser tab.
FTP doesn’t seem to be enabled either.
Status: Connecting to 10.0.0.18:21…
Status: Connection attempt failed with “ECONNREFUSED - Connection refused by server”.
Error: Could not connect to server
Any ideas on this one as its not totally bricked. It does serve properly and networks properly.
There isn’t a save box on the /UI/ssh page, all you have to do is tick the box and that enables it. If it’s not working, my guess is your dashboard is messed up so bad it’s not applying the change properly. Give it a try again and let me know, but without SSH you are really limited in what you can do to fix anything.
You can of course pop the drive out of the enclosure and recover your data and debrick it with either of my debrick guides.
Tried it again during the initialisation phase, but still doesnt enable. Tried the reset button button but same results, UI pages appear during initialisation phase then go blank when the LED is green. Still cant enable ssh.
So i think its messed up.
Was holding on to a faint glimmer of hope, so close but so far. Oh well.
Which debrick guide is the best course of action? I have the 3TB version. Does if wipe the whole drive?
Also want to put in one of your reset button scripts.
Sounds good… Are you able to make a direct sata connection to the drive once you pull it? USB to SATA cables are very hit and miss with the script for some reason.
Did you have a smart error in the dashboard by chance? If so ssh in and issue the command from the guide to fix it and then do a short diagnostic test from the dashboard
yeah I did have a dashboard smart error. I found that command in the instructions and did a short diagnostic which stopped at 90% but i left it and next i looked it was at 10% again and finished completely. diagnostic came back “Good”.
The Red flashing led remained untill i restarted the drive.
HD seems to be working alot, not sure what the active time is on that but it has idle periods so maybe im just seeing it when its busy. not sure whats happening, databases are up to date.
Got an alert for a firmware update but wont be doing that.
Dashboard shows current files as
Description:My Book Live Firmware
Version:MyBookLive 02.11.09-053 : Core F/W
Last Update:Tue 11 May 2010 04:35:06 AM EST
Made a image of the current setup and installed the reset button downgrade script and pointed it to that image so hopefull can recover to this same stage if required.
