URGENT - Differences between these WDTV models
Hi, please if someone can help me:
I’m buying some units of wdtv at USA.
What are the differences between these models?
WDBGXT0000NBK
WDBYMN0000NBK-HESN
OK, i now the WDBYMN0000NBK-HESN doens’t have Netflix today.
About WDBGXT0000NBK:
1- Does it have Netflix? Will it work at USA and Brazil?  ( i know the old version xxxx70000- hesn had netflix works well with netflix Brazil)
2- Is it only PAL?  can i switch to NTSC?
3- is it australian model?
4- any other difference?
WDBGXT0000NBK has Netflix available. However, the model corresponds to Europe and Australia. I am not aware if it will work in Brazil or in any other region. You can manually switch between NTSC and PAL signals in the settings.
Thanks!  But why does Western Digital don’t have a kind os release data with all the wdtv models and features?
We have to search and nothing exactly can be found.
Maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
http://support.wdc.com/contact/index.asp?lang=en
Support by Country
http://support.wdc.com/country/index.asp
When they were selling multiples, they did.  But the Gen 3 is no longer sold by WD, so there’s nothing to compare the newest with.
