My lag has disappeared
Thank you Dev.
I popped open my Task Manager and watched what happens and noticed my cpu was spiking to 100% during these searches. I unchecked the Auto-refresh under the preview window and now it only spikes to 70-90%.
I have 3GB RAM (2.75GB Usable, and an AMD Athlon™ II Dual-Core M320 2.1GHz laptop that I plug the external HDDs into for faster scans,rather than working off the network.
Now my only problem is with thumbgen and wd hub working in tandem.
I used the Black Mamba theme.bundle and everything went smoothe, however I’m missing some deail on the HUB itself. When I highlight a movie, the theme and movie sheet show up beautifully. With all the info. But when I press Options and go to “View Info”, for Say Daybreakers 2009. I get the proper Cover with the 97 Minutes written under it, as well as the proper background too. In the Info sections I got the following:
Total Time 98 minutes
Date: 2009-10-01
Star rating
Director: Peter Spierig
Genre: Drama
And the full movie Summary just fine.
But the Actor Field is listing N/A.
Now, bearing all that in mind. Out of curiosity I went back to highlight the movie, chose options, chose rescan info.
Now the backdrop is there but not what thumbgen created. Same for the intital cover thumb, no more minutes listed on it. I understand I just regrabbed info from a database so that was expected. Going into options and view info I get the new thumb showing (without minutes under it) and everything else, including all Actors. Which is great.
But I don’t know how to use thumbgen and the Black Mamba theme.bundle to have the best of both worlds. Basically, everything the theme.bundle does, PLUS to have that Actor info listed in the Options>View Info screen on the Hub.
Any help with this would be greatly appreciated.
