Badders
February 8, 2014, 10:05pm
1
I’m trying to create a safepoint on a 2TB Seagate Expansion drive connected via USB to my MyCloud 2TB; however, I get the following error message:
This safepoint operation failed due to an invalid request. (402007)
Any suggestions would be greatly appreciated.
Badders.
Any help would be appreciated.
Ichigo
February 9, 2014, 9:27pm
3
Hello Badders, check if you have the latest My Cloud firmware update, if you are using a USB powered hard drive, be sure to connect it directly to the My Cloud USB port, avoid using USB extension cables or non powered USB hubs.
http://www.wd.com/wdproducts/updates/?family=wdfmycloud_s
I get this message occaisionally but it usually goes through ok the next time it updates or if you do a manual update.
Badders
February 10, 2014, 7:34pm
5
No joy, firmware is up to date and have tried to manually create the safepoint unsuccessfully.
Any other ideas?
