WD Sync has lost the connection?
WD Sync has lost the connection, I try to do a correct translation of the message "WD own cloudstarage “MyCloud” is missing.
Network is up, I have connection with the My Cloud desktop app. It took several days to do all syncing. Is there a way to reestablish the sync connections?
Hi Thomas_Hoggren,
The link below will allow you to call support.
