WD TV Live freezes with Blu-ray Remuxed MKV
Hi! I’m having problems playing remuxed blu-rays. It freezes after a while. Time is random and only way is to unplug power on wdtv. When I play it again i can go back to where it freezed but after a while it freezes again. Never had any problem with Bluray.x264 or even untouched blu-ray. My firmware is the latest. Any tips? Tried different files. Here’s the info:
--(GENERAL)---
Container.......: Matroska
Size............: 8.7-13.1 GB per episode
Duration........: 0:52:36-1:01:37 (h:m:s) per episode
Source(s).......: Game of Thrones S01 1080p Blu-ray AVC DTS-HD MA 5.1 - HDChina
Chapters........: Yes (not named)
Compression.....: no zlib, no header stripping
Release date....: 26.02.2012
---(VIDEO)----
Codec...........: AVC
Type............: progressive
Resolution......: 1920x1080
Bit rate........: 18.5-30.0 Mbps per episode
Frame rate......: 23.976 fps
---(AUDIO)----
Format..........: DTS-HD MA
Channels........: 5.1
Bit depth.......: 24 bits
Sample rate.....: 48 kHz
Bit rate........: 4010-4070 kbps per episode
Language........: English
-(SUBTITLES)--
Format..........: PGS (original)
Language(s).....: English (SDH), Danish, Dutch, Finnish, French, Norwegian,
                  Polish, Portuguese (Brazilian), Spanish, Spanish, Swedish
Note: I’ve tried downgrading to 2 different firmware versions and the problem subsists.
Why don’t you post a “Proper”  MediaInfo output log file ?
(there’s a few things that could be cause of your woes … but your “Info” does not  provide enough details)
http://mediainfo.sourceforge.net/en
An example:
General
Unique ID :
Complete name :
Format : Matroska
Format version : Version 2
File size : 9.60 GiB
Duration : 2h 22mn
Overall bit rate : 9 637 Kbps
Encoded date : UTC 2012-08-06 15:59:48
Writing application : mkvmerge v5.7.0 (‘The Whirlwind’) built on Jul 8 2012 20:08:51
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 22mn
Bit rate : 9 000 Kbps
Width : 1 280 pixels
Height : 534 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.549
Stream size : 8.77 GiB (91%)
Writing library : x264 core 116 r2057 0ba8a9c
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=14 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=0 / bitrate=9000 / ratetol=1.0 / qcomp=0.65 / qpmin=0 / qpmax=40 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / nal_hrd=none / ip_ratio=1.25 / pb_ratio=1.25 / aq=1:0.65
Language : English
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 2h 22mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 653 MiB (7%)
Language : English
Default : Yes
Forced : No
Sorry. here it is:
General
Unique ID : 243419588086274087846737865589973573755 (0xB720E849B341E0AA8B981F2F5533E07B)
Complete name : F:\HIGH DEFINITION\HD\Series HD\Game of Thrones S01E01 Winter Is Coming 1080p Blu-ray Remux AVC DTS-HD MA 5.1 - KRaLiMaRKo.mkv
Format : Matroska
File size : 13.1 GiB
Duration : 1h 1mn
Overall bit rate mode : Variable
Overall bit rate : 30.3 Mbps
Movie name : Game of Thrones S01E01 2011 1080p Blu-ray Remux AVC DTS-HD MA 5.1 - KRaLiMaRKo
Encoded date : UTC 2012-02-26 07:30:05
Writing application : mkvmerge v5.2.1 (‘A Far Off Place’) built on Jan 2 2012 23:21:10
Video
Format : AVC
Duration : 1h 1mn
Bit rate mode : Variable
Bit rate : 28.2 Mbps
Maximum bit rate : 35.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.567
Stream size : 12.1 GiB (93%)
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
Duration : 1h 1mn
Bit rate : 1 561 Kbps / 1 510 Kbps
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Language : English
Default : Yes
Forced : No
Text #1
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Title : SDH
Language : English
Default : Yes
Forced : No
Text #2
Format : PGS
Language : Danish
Default : No
Forced : No
Text #3
Format : PGS
Language : Dutch
Default : No
Forced : No
Text #4
Format : PGS
Language : Finnish
Default : No
Forced : No
Text #5
Format : PGS
Language : French
Default : No
Forced : No
Text #6
Format : PGS
Language : Norwegian
Default : No
Forced : No
Text #7
Format : PGS
Language : Polish
Default : No
Forced : No
Text #8
Format : PGS
Title : Brazilian Portuguese
Language : Portuguese
Default : No
Forced : No
Text #9
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #10
Format : PGS
Language : Spanish
Default : No
Forced : No
Text #11
Format : PGS
Language : Swedish
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:00:06.006 : en:00:00:06.006
00:07:16.436 : en:00:07:16.436
00:08:56.536 : en:00:08:56.536
00:18:14.510 : en:00:18:14.510
00:28:46.558 : en:00:28:46.558
00:39:35.582 : en:00:39:35.582
00:50:00.039 : en:00:50:00.039
01:00:32.629 : en:01:00:32.629
