What would be a good normal operating temerature for a WD2500KSRTL Sata II Drive? I have one that is only about one year old but it seems to run hot! All fans are working properly. I went ahead and added a new slot case fan to try to cool it down even more. Most of my drives operate in the 30 - 40 degree C. This drive seems to go
between 47 - 58 degree C. even with the new fan. Could the bearings be going bad and should I consider getting this one changed out soon? Thank You
