There are some warning signs for my Western Digital WD5000AAKX purchased 5 months ago.
Both The Diagnostic tests with WD Data Lifeguard Failed (Quick and Extended).
Here are the results
Test Option: QUICK TEST
Model Number: WDC WD5000AAKX-001CA0
Unit Serial Number: WD-[Deleted]
Firmware Number: 15.01H15
Capacity: 500.11 GB
SMART Status: PASS
Test Result: FAIL
Test Error Code: 06-Quick Test on drive 3 did not complete! Status code = 07 (Failed read test element), Failure Checkpoint = 97 (Unknown Test) SMART self-test did not complete on drive 3!
Test Time: 16:02:06, January 01, 2012
Test Option: EXTENDED TEST
Capacity: 500.11 GB
SMART Status: PASS
Test Result: FAIL
Test Error Code: 08-Error was detected while repairing bad sectors.
Test Time: 17:32:18, January 01, 2012 [/CODE]
After that I tested it with HDtune.
The health tab in HDtune shows ok while a surface scan shows 6 bad blocks.
Two SMART attributes are being shown as caution in Crystal Disk Info
Current Pending Sector Count - 8 (raw value)
Uncorrectable Sector Count - 3 (raw value)
Screenshots
http://www.stooorage.com/show/1080/5235859_hdtune_health_wdc_wd5000aakx-001ca.png
http://www.stooorage.com/show/1080/5235861_hdtune_error_scan_wdc_wd5000aakx-001ca.png
Now the question is - What does all this mean ?
Is this HDD going to fail in short term ?
Should I create an RMA ?
Please advice about the same.
