Hi, I cannot get WDTV subtitles to switch on on the player. I went into WDTV ‘Setup’ and ‘Video settings’ and switched ‘Default Subtitles’ to ‘On’. However when i then start the video file in the top left of the screen it stil says ‘Subtitles: Off’. If i press the subtiles button on the WD Remote it still does not switch to ‘On’. I don’t think the issue is with the subtitle (.srt) file as i have got the subtitles to work prevously, this is a new problem.
Whn you say this is a new problem…does that mean it was working previously (i.e. before a firmware update) on the WDTV and now it isn’t?
You might wsnt to try and put the .srt into the mkv itself and set it to default and see if that works…this is the way I deal with mkv’s and subtitles, but I stream over DLNA.
