My Book 3TB / USB 3.0/2.0 Not connecting to Sony BluRay BDP S380
Having trouble - is this drive FULLY USB 2.0 compatible?
My WD 1.5 TB USB 2.0 drive works, and a flash drive NTSB formatted works.
Any thoughts? I downloaded the latest firmware for both the drive and the BDP S380.
It may be the drive size. NTFS drives less than 2 T use MRB if they are larger than 2 T they need GPT. Does Sony use the GPT as well as MRB?
Joe
Thanks - will ask Sony if they do MBR AND GPT.Ā  Very helpful.
Will actually try a powered USB hub to see if that does the trick.
John
Is there any way to partition the drive and have both ā€œdrivesā€ be MBR only?
I’m not a techie…
Sony said it will NOT support a drive greater than 2.0 TB.
