I completely lost the ethernet connection after an update. I do not see the ethernet leds in the back lit up. The front led is always blue. I have tried direct connection to a Windows 7 PC as well as my home router. I even tried to reset the drive using pin. It was working before although I used it only sparingly.
I can request for RMA but before I do that I want to erase any personal data on the drive.
any solution for the network connection?
