Hello
I just bought a nas mycloudex2 ultra.
However, when I click on “add content”,
I have the following page opening with errors (http://www.mycloud.com/learn/?language=en#mc-upload):
Thank you in advance for any help.
Arnauld
Hello
Arnauld
Hello damienbourgeois,
You seem to add data to your my cloud device from the dashboard . Which is not the right method to transfer data on your device.
Either you can access My cloud.com and upload your data from there or you can map the shares on your computer and upload data to the device manually. Also, you can use WD Smartware software or Windows files history backup feature to transfer your data to the my cloud device
Adding data through My Cloud.Com:
How to map your shares on windows computer:
Backing up Windows or Mac to WD Network Attached Storage (NAS):
thank you logan.h,
I’m using Ubuntu.
What I did is :
-going to http://mycloudex2ultra.local/ using a web browser
-I created a new folder below “Set Up Shares”
-then I browse my network from my computer(Ubuntu) to the new folder I just created in my nas and copy manually the files to this new folder.
Is it the right way to add stuff ?
Yes, you would need to manually transfer the data to the share that you can see in the Network option of your Ubuntu system.
ok, thank you logan.h.
