No audio - MKV file
Hello, the video for this MKV file plays fine but there is no sound, anybody know why?
No need for screenshots, export Mediainfo’s text!
How is your WD hooked up?  HDMI?  Optical?   Analog?
Hooked up with HDMI cable
Video
ID/String                        : 1
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format_Profile                   : High@L3.0
Format_Settings_CABAC/String     : No
Format_Settings_RefFrames/String : 1 frame
CodecID                          : V_MPEG4/ISO/AVC
Duration/String                  : 1h 51mn
BitRate_Nominal/String           : 1 600 Kbps
Width/String                     : 960 pixels
Height/String                    : 540 pixels
DisplayAspectRatio/String        : 16:9
FrameRate_Mode/String            : Constant
FrameRate/String                 : 29.970 fps
ColorSpace                       : YUV
ChromaSubsampling                : 4:2:0
BitDepth/String                  : 8 bits
ScanType/String                  : Progressive
Bits-(Pixel*Frame)               : 0.103
Encoded_Library/String           : x264 core 80 r1378+57 6f6b50a
Encoded_Library_Settings         : cabac=0 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=0 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=1600 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default/String                   : Yes
Forced/String                    : No
Audio
ID/String                        : 2
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format_Profile                   : Main
CodecID                          : A_AAC
Channel(s)/String                : 2 channels
ChannelPositions                 : Front: L R
SamplingRate/String              : 44.1 KHz
Compression_Mode/String          : Lossy
Forced/String                    : No
I removed header compression, still no audio.
If you hook up through HDMI, make sure you select AUTO on AUDIO selection, otherwise the WD may be trying to send un-decoded AAC to the receiver which probably doesn’t support it.
Hey, thanks for your replies, my hookup is the WDTV to the television with an HDMI cable, no external speakers/receiver hooked up, for audio I have -stereo- selected, I played the video with HDMI pass through (auto) selected still no audio, audio works fine when playing on the PC, I guess I will just convert the audio to mp3.
