I Have wd TV it’s work OK but I have new mkv file it can’t play and it’s hang with the rest of files. PLZ can you advise me step by step.
Thanks a lot.
Thanks a lot.
Check for compression. Use MKVINFO to find a line whether the merge was compressed or not. If it was, you can extract it and remerge, but remember to turn off compression.
I just tried all the above the movie start but it hung on the beginning…
Have you reset your WDTV before playing the new MKV.
Yes of course.
Post the mediainfo of the ‘bad’ file.
(MKVInfo) + EBML head
(MKVInfo) |+ EBML version: 1
(MKVInfo) |+ EBML read version: 1
(MKVInfo) |+ EBML maximum ID length: 4
(MKVInfo) |+ EBML maximum size length: 8
(MKVInfo) |+ Doc type: matroska
(MKVInfo) |+ Doc type version: 2
(MKVInfo) |+ Doc type read version: 2
(MKVInfo) + Segment, size 7060115593
(MKVInfo) |+ Seek head
(MKVInfo) | + Seek entry
(MKVInfo) | + Seek ID: 0x15 0x49 0xa9 0x66 (KaxInfo)
(MKVInfo) | + Seek position: 4099
(MKVInfo) | + Seek ID: 0x16 0x54 0xae 0x6b (KaxTracks)
(MKVInfo) | + Seek position: 4262
(MKVInfo) | + Seek ID: 0x1c 0x53 0xbb 0x6b (KaxCues)
(MKVInfo) | + Seek position: 7059965913
(MKVInfo) |+ EbmlVoid (size: 4043)
(MKVInfo) |+ Segment information
(MKVInfo) | + Timecode scale: 1000000
(MKVInfo) | + Muxing application: libebml v1.0.0 + libmatroska v1.0.0
(MKVInfo) | + Writing application: mkvmerge v4.3.0 (‘Escape from the Island’) built on Sep 5 2010 10:30:51
(MKVInfo) | + Duration: 6207.201s (01:43:27.201)
(MKVInfo) | + Date: Thu Sep 09 23:20:19 2010 UTC
(MKVInfo) | + Segment UID: 0x98 0x8c 0xf7 0xd5 0xa7 0xb6 0x71 0x92 0x99 0x46 0xc9 0x3d 0xed 0xbc 0x7c 0xef
(MKVInfo) |+ Segment tracks
(MKVInfo) | + A track
(MKVInfo) | + Track number: 1
(MKVInfo) | + Track UID: 1636874124
(MKVInfo) | + Track type: video
(MKVInfo) | + Lacing flag: 0
(MKVInfo) | + MinCache: 1
(MKVInfo) | + Codec ID: V_MPEG4/ISO/AVC
(MKVInfo) | + CodecPrivate, length 56 (h.264 profile: High @L4.1)
(MKVInfo) | + Default duration: 41.708ms (23.976 fps for a video track)
(MKVInfo) | + Name: The Expendables
(MKVInfo) | + Video track
(MKVInfo) | + Pixel width: 1280
(MKVInfo) | + Pixel height: 544
(MKVInfo) | + Display width: 1280
(MKVInfo) | + Display height: 544
(MKVInfo) | + Content encodings
(MKVInfo) | + Content compression
(MKVInfo) | + Algorithm: 3 (header removal)
(MKVInfo) | + Settings: length 1, data: 0x00
(MKVInfo) | + Track number: 2
(MKVInfo) | + Track UID: 1954314154
(MKVInfo) | + Track type: audio
(MKVInfo) | + Codec ID: A_AC3
(MKVInfo) | + Default duration: 32.000ms (31.250 fps for a video track)
(MKVInfo) | + Name: English AC3 5.1 @630Kbps
(MKVInfo) | + Audio track
(MKVInfo) | + Sampling frequency: 48000
(MKVInfo) | + Channels: 6
(MKVInfo) | + Settings: length 2, data: 0x0b 0x77
(MKVInfo) | + Track number: 3
(MKVInfo) | + Track UID: 12818590
(MKVInfo) | + Track type: subtitles
(MKVInfo) | + Codec ID: S_TEXT/UTF8
(MKVInfo) | + Language: rum
(MKVInfo) | + Name: Romanian
(MKVInfo) | + Track number: 4
(MKVInfo) | + Track UID: 1222167943
(MKVInfo) | + Default flag: 0
(MKVInfo) |+ EbmlVoid (size: 1185)
(MKVInfo) |+ Cluster
It has Header Compression. Check the FAQ.
So help me how can I remove Header Compression
amro_
You will have to roll up your sleeves a little to “fix” your MKV. I hear WD will soon release a firmware fix for the WDTV Live. But until then, this guide should provide you all the tools and info you need:
http://wdtvforum.com/main/index.php?topic=6897.0
I have used this method myself -it works well.
Cheers,
BR
As Tony said, you can read the FAQ.
But basically you need to either run it through MKVMerge 4.0 or earlier (the “good” version) or take a later version of MKVMerge and turn off video and audio headers.
As I said before follow all the instructions on the link I gave you. Look at the picture and turn off the compression on video and audio.
